Page 1 of 2
Uneven Worktop Join
Posted: Sat Nov 26, 2011 11:41 am
by rafiKi
Hi all,
I have just had a kitchen work surface fitted and there is an uneven join on one of my counter tops. The join was mitred, colourfilled and bolted - but no biscuits were used.
The join/colour fill was made 7 days ago but I have only just come back to see the excess colour fill be removed and the slight raise in the join. One piece is half a milimeter higher than the other.
My question is this - is it possible to loosen the bolts, seperate the joined laminated work tops and then re-join them level?
Many thanks,
rafiKi
Re: Uneven Worktop Join
Posted: Sat Nov 26, 2011 11:52 am
by rafiKi
Sorry - The reason that I am asking is that the kitchen fitter has said no, as the colour fill has bonded the work top... but I cant seem to verify that online.
Posted: Sat Nov 26, 2011 12:31 pm
by Colour Republic
Depends how much colour fill was used. It's still possible but could be a right pain to do with the worktops maybe having to come right out again along with sink and hob....
Is it like it the whole way along or just on one bit? Is it possible the worktops are cupped and if so who supplied the worktops? i.e you or the fitter?
Posted: Sat Nov 26, 2011 12:46 pm
by thescruff
A pic or two may be an idea.
Posted: Sat Nov 26, 2011 2:47 pm
by rafiKi
It had about half a tube of colour fill over 2 mitre joins - the left mitre join is seamless... the right mitre join is out the whole way along. I will take a pic later and up it. It is not the material that is the issue as far as i can tell - just that one needs to be pulled half a mil to a mil lower and then re-bound.
Posted: Sat Nov 26, 2011 3:02 pm
by thescruff
Can you get them back, and have you paid them.
Posted: Sat Nov 26, 2011 3:33 pm
by rafiKi
paid - mostly but not completely. No, I can't get them back but have other contacts who could help me for free if I ask right - but they are away for the week. I just want to know if it's something that can or can't be rectified by just loosening the bolts and re-aligning and sealing? If not, I guess i'll have to alert the troops upon their return.
Posted: Sat Nov 26, 2011 3:43 pm
by thescruff
See what the pic show, but would have thought so.
Posted: Mon Nov 28, 2011 5:28 pm
by fin
depending on the colour of the work tops i find it easier to use clear silicone. as you dont seem to get much time to work with that colourfill stuff. plus its easier to clean off than colourfill.
are the tops 28mm or 38mm?
Posted: Mon Nov 28, 2011 7:33 pm
by joinerjohn
Must admit that colorfill seems to have a very , very short working life. Once you open the tube and put it on, you have to work like the clappers to level the joint up and tighten the dogbones. As Fin says,, I sometimes use either clear or coloured silicone (depending upon the worktop.
Posted: Fri Dec 02, 2011 4:44 pm
by fin
Posted: Sat Dec 03, 2011 8:20 pm
by royaloakcarpentry
Blimey, am I the only craftsmen who uses 1 tube of colourfill per joint?
Posted: Sat Dec 03, 2011 8:28 pm
by Colour Republic
royaloakcarpentry wrote:Blimey, am I the only craftsmen who uses 1 tube of colourfill per joint?
No
And am I the only one who uses biscuts?
Posted: Sat Dec 03, 2011 8:31 pm
no LOL
Posted: Sat Dec 03, 2011 8:34 pm
by ayjay
No.
I can't work out how he managed two joints using half a tube.
Colour Republic wrote:
And am I the only one who uses biscuits?
I've always considered biscuits to be a waste of time in worktop joints, the chipboard core is just too soft for them to be of any use.
