bosch 10.8v inspection camera
Bosch power tool review in here please.
Has thanked: 734 times
Been thanked: 2333 times
http://www.ffx.co.uk/tools/product/3165 ... nit%20only
brilliant bit off kit not cheap at £139 without batteries or charger
excellent quality picture on the 54x40mm visible screen or 2.5" in old money
it takes a bit off getting used to if you need full orientation you often have to rotate the cable along its length so the visible picture is the same angle as the camera and not for example up side down
the battery goes on for hours so one on its own would be fine
even if the battery goes flat a 15 min part charge will give you around a 60% charge
there are only 3 buttons on/off and plus or minus for the light
there are 3 clever attachments a right angle mirror a strong magnet and a hook attachment
any one with aeg 10.8v tools should look at the aeg inspection camera and recip saw as they are identical so must be a combined venture
transitboy
Has thanked: 379 times
Been thanked: 584 times
Re: bosch 10.8v inspection camera
Post by transitboy »
big-all.Considering price above found a com-bi deal with screwdriver and inspection camera,plus two batteries for £249.95.Sorry wont let me put a link up for the site.
Return to “Bosch”
