Cedral cladding
Posted: Fri Jan 20, 2012 8:29 pm
by ayjay
Just finished this lot, I sincerely hope that I never have to use the stuff again.
House
- IMG_4532-r.jpg (325.54 KiB) Viewed 2304 times
Garage
- IMG_4535-r.jpg (381.76 KiB) Viewed 2304 times
and even the shed
- IMG_4534-r.jpg (378.47 KiB) Viewed 2304 times
Re: Cedral cladding
Posted: Fri Jan 20, 2012 8:48 pm
by speed
wow looks like you had fun
i fitted some afew years ago not as much as you tho (thank god) and it still looks as good now as the day i fitted it
what did you use to cut it?
Re: Cedral cladding
Posted: Fri Jan 20, 2012 9:27 pm
by Hitch
Continuous diamond blades work well on cement fibre roofing sheet, but normal tct wood blades cut it fine....probably need a new blade for doing decent stuff after though....thats what Cedral is isn't it?
Looks a nice install job.
Almost makes it look American
Re: Cedral cladding
Posted: Fri Jan 20, 2012 9:39 pm
by ayjay
speed wrote:wow looks like you had fun
I've had all the fun I need for now!
Diamond blade in the boss's chop saw to start with but it just kept clogging up with the dust on the slide rails, (needs a complete strip down and clean now) in the end I just used a diamond blade in a small angle grinder - windy days were best.
It took the edge off a TCT blade very quickly.
