Hello
I'm trying to fit some 12mm quadrants to our PVC windows with plasterboard surround, but having problems with the top length. How on Earth would I get this to stay in place, without cutting several timber posts to length and supporting? The window is ~2.5m wide.
I've tried contact adhesive - didn't hold. The weight of the quadrant pulled it down. I don't suppose it helps that the length isn't perfectly flat either.
Loathed to try sticking it up with silicone, grip fill, evo-stick, etc... No means of supporting the thing for hours while it goes off.
Thoughts appreciated and thanks in advance.
Fitting Window Quadrants
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Re: Fitting Window Quadrants
You could use silicone and some sticky pads to hold the trim in position until the silicone cures, like in this method-
Or you could use Everbuilds Maximum torque grab adhesive-
