Ive got some 600 x 300 tiles to fit in a shower enclosure. What adhesive would you recommend?
They are being fitted onto new plasterboard stud walls if that helps.
Which adhesive?
- Has thanked: 5 times
- Been thanked: 23 times
Re: Which adhesive?
What type..colour...are they?
Stone tiles will require a White flexy rapidset adhesive...and seal before and after grouting..
Porkies will need a porcabond adhesive
A bagged cement based adhesive....mapei/ardex/weber/bal....ect..
Are you tanking the wet area,will the plasterboard take the weight per m2....
