glued skirting
- Has thanked: 3 times
glued skirting
i guys,
i removed all skirting for wooden floor now i want to put it back after finished with floor but almost all skirting have some sort of glue on back side which was used by builders now i have to remove it any best idea how to remove it?
i also wander where from i can get that sort of glue to use again to fix skirting???
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
- Hoovie
- Borders Bodger
- Been thanked: 4 times
Glued only is fine
To remove the glue, you could also try one of these - they are great at removing all sorts of 'stuff' sticking out
Heavy-Duty Scraper
Heavy-Duty Scraper
- Andy Davies
I recently had to fix skirting to walls as bent as a 9 pound note and was equally as worried that the grab adhesive wouldn't be strong enough
However as long as you brace the skirting in place (thanks again Hoovie!)until the glue fully dries it will be rock solid
The glue I used was "Sticks like sh!t" from Screwfix - I don't know if it's the best one out there, but it says "Trade Only" on the container which is good enough for a beginner at DIY like me and convinced the boss that I knew what I was doing
- Wood Magnet
- Been thanked: 3 times
- Tryanything
Hi
Yes i agree with Wood Maggot oops
Hammer and chisel
One other thing dont hammer the nails out as this will probably splinter the face of the skirting try and pull then all the way through probably splinter on the back but will leave the filler and paint in tact on the face side
Sorry Wood Magnet couldn't resist
Hammer and chisel
There would be less trouble in the world
if l had not had six daughters
- Wood Magnet
Tryanything wrote:Hi
Hammer and chisel
People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's.
