Bosch PMF180 E to remove grout - but tiles very close
neanderthal man
Has thanked: 15 times
Post by neanderthal man »
Hi everyone
We have bought a Bosch PMF180E deluxe kit to help with grout removal.
According to the instructions the recommended tool to use is the ACZ85RT. Some of the tiles are very close together and given the thickness of this tool I am very likely to damage a tile.
I have view the video here -> http://www.youtube.com/watch?v=JG6Xtggs ... plpp_video <- of UHM using the PMF180E to remove grout and he says he is using a tile cutting blade but I am not sure I have such a tool.
So I can use the ACZ85RT where I think there is enough room for the tool to work but what would be the best way to remove grout where tiles are very close together with very little room to get between them.
Any advice would be much appreciated.
Has thanked: 1012 times
Been thanked: 918 times
Re: Bosch PMF180 E to remove grout - but tiles very close
Post by ultimatehandyman »
The ACZ85RT is the tile cutting blade. If the grout lines are not wide enough you will not be able to use it!
If you have an old wood cutting blade you could try using that as they are thinner.
neanderthal man
ultimatehandyman wrote:The ACZ85RT is the tile cutting blade. If the grout lines are not wide enough you will not be able to use it!
Thanks for the reply UHM.
There are examples in the papework showing that the ACZ85RT can be used for removing grout.
But given the brass coloured rough edges to the blade I am surprised that it can be used for cutting actual tiles. The blade is quite thick and the rough edge doesn't seem suitable for cutting tiles finely.
I actually have a tile to cut so you sure it is ok to use the ACZ85RT for this purpose?
Cheers.
It'll cut ceramic tiles but not porcelain.
There is an example here about 4 minutes in-
http://www.youtube.com/watch?v=MB3kU6mGjng
There are much easier and quicker ways of cutting tiles but if you have nothing else one of these should do!
neanderthal man
ultimatehandyman wrote:It'll cut ceramic tiles but not porcelain.
I forgot about that video - thanks for the reminder.
We bought a couple of white tiles to plug a gap and they need cutting to fit but have no idea what they are made of.
Is there an easy way to tell if a tile is ceramic or porcelain just by looking at it or feeling it?
Sorry, don't know
transitboy
Has thanked: 379 times
Been thanked: 584 times
Post by transitboy »
try drilling a hole if ceramic it will drill fairly easy if porcelain you will know very quickly
fein does a blade what you are looking for, but is very expensive.if you have a dremmel they do one also and it is a lot cheaper but is not really suited if you have a lot to do http://www.axminster.co.uk/fein-fein-su ... rod814300/
Return to “Tiling Forum”
