Vinyl over ceramic tiles????? - Help Meeeeeeeeeee
Nikki57
Has thanked: 3 times
Post by Nikki57 »
I have a ceramic tiled kitchen floor which is VERY slippery & needs some good quality safety flooring.Any advice on wether to remove them/board it or would a good thickness & quality hide grout lines from present tiles?.Any advice appreciated.I
would be covering a large kitchen of 14-16 sq meters
Picture 6563.jpg (402.76 KiB) Viewed 1469 times
Inky Pete
Has thanked: 12 times
Been thanked: 161 times
Re: Vinyl over ceramic tiles????? - Help Meeeeeeeeeee
Post by Inky Pete »
I wouldn't bother going to the bother of ripping them up. A decent thick vinyl will cover nicely.
These users thanked the author Inky Pete for the post:
Nikki57
Nikki57
Post by Nikki57 »
Thanks Pete.I was advised yesterday that even a good thickess of quality vinyl would just sink into the grout areas after only a year or two..Hence asking for advice.I also forgot to ask what type of adhesive is need to lay a safety flooring vinyl of a minimum of 3-5 thickness.
Colour Republic
Has thanked: 263 times
Been thanked: 544 times
Post by Colour Republic »
To do it correctly you should take up the tiles but the next best thing would to be to SLC over the old tiles after roughing them up
These users thanked the author Colour Republic for the post:
Nikki57
DTWCeramics
Has thanked: 13 times
Been thanked: 43 times
Post by DTWCeramics »
As colour has suggested, best would be to level the floor with a decent self levelling compound, then use your vinyl as it'll dip down into the grout joints after a short time.
Just consider how much height you will be adding with this when you are doing it however.
These users thanked the author DTWCeramics for the post:
Nikki57
Return to “Tiling Forum”
