moisture barrier equivelant
Locked
Topjacket
Has thanked: 13 times
Post by Topjacket »
Hello All
I am having walnut worktops delivered and fitted this week but the company we got them from didn't have any of the moisture/heat barrier sheet in stock (I think this is the correct name, basically its the stuff you stick under the worktop to stop dishwashers and washing machines affecting the wood).
I thought that this would be something I could pick up at screwfix or B&Q but it seems I was wrong. With time being an issue does anyone know if there is product that could be used as an equivelant that can be bought in a shop and not mail order?
I was wondering if the radiator reflectors would be any good?
Thanks in advance for any help.
Cheers
Jim
speed
Has thanked: 35 times
Been thanked: 257 times
Re: moisture barrier equivelant
Post by speed »
foil is usually supplied with the dish washer
http://www.toolstation.com/shop/Adhesiv ... 420/p81953
its just that stuff
These users thanked the author speed for the post:
Topjacket
Topjacket
Post by Topjacket »
Great! Thanks very much for your quick reply.
Cheers
Jim
Loosenup
Has thanked: 3 times
Been thanked: 8 times
Post by Loosenup »
b&q actually do a large sheet the size of a washing machine in the kitchen dept.
Locked
Return to “Kitchen Fitting”
