14.4v hitachi 2x 3ah li-ion drill kit £150
The Bargain Tool forum. This is for regular members to post about bargain tools. It is not for spammers to post links to tool sites!
Has thanked: 736 times
Been thanked: 2341 times
good company add a angle grinder and jigsaw for £100
http://www.ffx.co.uk/tools/product/4966376147991
mark21lancs
Has thanked: 4 times
Been thanked: 13 times
Re: 14.4v hitachi 2x 3ah li-ion drill kit £150
Post by mark21lancs »
i personally own a professional Bosch SDS plus hammer and its never failed me, 2nd to none and at the price your looking at you can buy a high end bosch off ebay for less that will last you years
this is same as mine, plus 3 batteries
http://www.ebay.co.uk/itm/Bosch-24v-SDS ... 500wt_1287
see what you think
Bikergirl
Has thanked: 100 times
Been thanked: 133 times
Post by Bikergirl »
I use a hitachi 18v drill driver- it was the best I could afford when I started out, and after 18 months of a lot of use, it's still fine. I often use a sanding disc in the drill for large areas, so it gets quite a lot of use.
The hammer function is ok- won't do concrete, but at 18v I don't expect it to.
Would definitely get another.
mark21lancs
just in case you need it for concrete the one above will work
mikew1972
Has thanked: 10 times
Been thanked: 110 times
Post by mikew1972 »
Yep you often get the much better 18v version of that Hitachi drill on offer for under £100 with 2 Li-ion batteries just the same (just lower capacity in the batteries unfortunately but 3ah ones are available for it)
Mike
speed
Has thanked: 35 times
Been thanked: 257 times
Post by speed »
mikew1972 wrote:Yep you often get the much better 18v version of that Hitachi drill on offer for under £100 with 2 Li-ion batteries just the same (just lower capacity in the batteries unfortunately but 3ah ones are available for it)
the drill thats usually £100 is a totally diffrent drill, smaller/cheaper/flimsier diy grade
http://www.ebay.co.uk/itm/HITACHI-DV18D ... 077wt_1141
http://www.ebay.co.uk/itm/Hitachi-DV18D ... 353wt_1189
Marty7787
Post by Marty7787 »
Would never buy Hitachi again, went through 3 of those in about 2 months, in the end just got a refund and went elsewhere.
GavHandy
Been thanked: 32 times
Post by GavHandy »
mark21lancs wrote:i personally own a professional Bosch SDS plus hammer and its never failed me, 2nd to none and at the price your looking at you can buy a high end bosch off ebay for less that will last you years
see what you think
They are two completely different machines, you would have a job driving screws/drilling joists etc using an SDS. An SDS complements a Combi drill
Return to “Bargain Tools”
