Slow Broadband? Try this
phill
Has thanked: 2 times
Been thanked: 10 times
Post by phill »
If you want to speed up your Broadband go to the master socket and pull off the "bell wire" (connector 3)
My BB increase from 3.1 to 3.4 Meg my mate Ian went from 1 to 3 meg
It seems this wire is not needed these days and acts as an aerial and adds noise to the line, slowing the BB down
I measured my BB speed on the router, before and after.
I doubt this mod is approved by any of the Telco's and you do it at your own risk, but you could always pop the wire back on if you wanted!
Phill
phill
Post by phill »
:scratch: Has nobody tried this yet?
brixtonian70
Post by brixtonian70 »
What master socket, and what bell wire, are you talking about the telephone socket? I only have 2 wires attached.
phill
Post by phill »
The master socket is the one where the line from outside comes into the house.
What then happens is connectors 2 3 and 5 are all wired up to the other sockets in the house.
You only need 2 and 5 for the phones, 3 is no longer used.
Phill
old_codger
Post by old_codger »
I've had the cover off the main socket but don't remember there being a connector three, tbh. What colour is the wire? Do you remember?
old_codger
Existing socker wiring
OK! Hers's my BT main socket wiring.
Main socket backplate wiring, (you can see outer connector plate behind it in tis picture).
Main BT socket outer connector plate
Return to “Computers”
