been asked to fit a kitchen for a mate of mine. i currently have a 48 tooth and an 80 tooth blade but they have both been used for various stuff. possibly a touch blunt. i could get em sharpened up but i was wondering what you guys use when fitting cornice / lighting pelmet etc.
these are the blades im currently using.
http://www.ebay.co.uk/itm/Bosch-216mm-T ... 500wt_1054
though iirc they werent that expensive when i got em
also ive seen that stuff that disolves the sap and all that on blades after theyve been used a fair bit. one of mine i ended up scraping clean. does it work well?
btw the machine is a dewalt dw701
cheers fellas
chop saw blade for cornice etc
- Has thanked: 35 times
- Been thanked: 257 times
Re: chop saw blade for cornice etc
ive just got some trend craft pro blades to try,
i think that should fit yours? proper mitre saw blade not a circular saw blade,
edit, help if i add the link
http://www.powertoolworld.co.uk/mitre-s ... lades.html
- Has thanked: 32 times
- Been thanked: 807 times
cool.. i used the 80 tooth last time. but sorta forgot it was stil on and its been used for all sorts. only realised when i was cutting a bit of 4 x 2 up into loadsa wedges and smoke came off it. oops... haha
haha yep if you remember after not using it for a couple of weeks though.
ill send mine off to be sharpened up aswell. the local timber yard sends the table saws blades to get sharpened and they said i can send mine off with em aswell. canny of them.
