Bosch GCM 12 GDL Glide Mitre Saw
Bosch power tool review in here please.
orm29
Has thanked: 29 times
Been thanked: 4 times
Post by orm29 »
Had this a few months now. Although it's not received exhaustive professional use i feel i have used it enough to offer my opinions on the product.
It's a very good saw, i bought it because the glide arm seems to offer what no other saw could. That being, the cutting capacities of a 12" saw with the accuracy of a 10". It does this, don't get me wrong you can't just slam the thing down on to your work and expect a perfect cut (not that you would with any saw, no matter its size), but with care and a gentle touch (i've adopted the technique of using the handle to guide the blade whilst putting as little weight on it as possible), there's no detectable deflection.
As for all other areas, i won't bother going in to chapter and verse, but it is very good all round as you would expect for an £800 saw.
These users thanked the author orm29 for the post:
Job and Knock
Old School Chippie
Has thanked: 742 times
Been thanked: 1573 times
Re: Bosch GCM 12 GDL Glide Mitre Saw
Post by Job and Knock »
What about weight and portability? Very important for me as a tradesman
Has thanked: 740 times
Been thanked: 2355 times
the lack off overhang on the back is amazing
can you trench with it :dunno: :dunno:
orm29
Post by orm29 »
It is a heavy beast and not the easiest to lug around. If you couple it with the GTA2500 it is fine, but you'll need a big van as the whole setup takes a lot of space.
Yes it trenches, used this function on quite a few projects and it does it very nicely.
Return to “Bosch”
