Splashbacker Board. ?
Locked
martyn1967
Has thanked: 2 times
Been thanked: 26 times
Post by martyn1967 »
I'm in the process of a fitted kitchen which is not having tiled splashbacks. Instead we have a jamocha laminated mdf sheet to match worktops. I have not used this before and would like some advice Please.
Best adhesive?
Window Corners & cill ? do i treat this the same way an edging strip in tilig? Reveals aint exactly sq neither.
On a straight run of wall units, is it better to let units overlap backer board, packing out top brackets to suit?
Sealant?.
Your Advice & Tips are much appreciated. :salute:
What would you rather bee or a wasp!
speed
Has thanked: 35 times
Been thanked: 257 times
Re: Splashbacker Board. ?
Post by speed »
last time i fitted some i used mega grip adhesive from tool station.
cut to the under of the wall units and for the tops/corners you get a colour matched trim like tile trim.
for butt joins i routed both edges for a good fit and aded a little glue on the join,
the last set of backer i got was cupped so just check them and watch how you store them
martyn1967
Cheers speed, i sandwiched them between worktops when kitchen was delivered to ensure theyre flat as a pancake
Locked
Return to “Kitchen Fitting”
