I asked the question a while back. Laying ply in bathroom on top of existing planks ... it will get plastic tiles on top of it. I was told the underside and edges should be primed and at the time it was suggested to use either SBR or Acrylic primer.
Can I use oil based primer? Which I will be using on some other jobs, e.g. http://www.crowntrade.co.uk/Products/Pr ... rimer.aspx
TIA
Primer for bathroom floor ply
- DTWCeramics
- Has thanked: 13 times
- Been thanked: 43 times
Re: Primer for bathroom floor ply
Hi OA,
This primer seems to be for paint, but as you're not actually using proper tiles as such, might be ok.
Probably best to contact Crown or tile manufacturer/supplier.
Personally I'd use the Ardex P51 primer, cause it's awesome and blue!
Cheers
Cheers
Matt
- Has thanked: 855 times
- Been thanked: 994 times
We are talking about the underside of the ply, yes? Not the side on which the tiles would be stuck (so moisture levels are the same top and bottom side).
- DTWCeramics
I don't see why you'd need to prime it at all.. just screw it down?
It's not going to hurt to prime the wood at all, assuming this is standard WPB?
Matt
