How do I wire new light fitting
Locked
wintermute
Post by wintermute »
I've bought a new light fitting but I'm confused as to how I should wire it up. The new fitting comes with a plastic terminal connector whereas the current light is wired through the ceiling rose.
I've attached a diagram and would appreciate any help in transferring the connections to the new fitting. I've labelled the connection points to hopefully simplify any explanations.
I've left out the Earth from the ceiling rose diagram to make it more readable.
Rich-Ando
Pro Tradesman
Has thanked: 135 times
Been thanked: 304 times
Post by Rich-Ando »
hi wintermute, welcome to the forum
:hello2:
turn off your lighting circuit and connect the wires as follows: -
A&B together
C/D&E together
F/G&H together
the earths together
(obviously A & H will be from your new light and not the pendant from your existing light)
it doesn't really matter which numbers you use in the blocks as long as you connect the wires as i have described.
wintermute
Cheers Rich-Ando. I'll try it out this weekend.
Rich-Ando
Pro Tradesman
Post by Rich-Ando »
no prob, that's what the forum is for. let us know how you get on :thumbright:
Locked
Return to “Lighting”
