Moving Programs from drive C to D
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
Have two programs (Dropbox and Google Drive) that are loaded in drive C, (100GB) whats the easiest way to move them to Drive D, they are use up nearly all drive C.
- Has thanked: 1 time
Re: Moving Programs from drive C to D
You will either have to uninstall Dropbox and Google Drive and reinstall them in drive D...or set the programmes to store the files in in drive D...this may be done in the settings of the software...I do not use any of these programmes but these are common rules....If you cant redirect you files to D drive within the software you will have to reinstall in D drive...
- thescruff
Not tried dropbox yet, but Google drive wont give me the option to install in drive D
- BillyGoat
- Troll Headbutter
- Has thanked: 386 times
- Been thanked: 796 times
- thescruff
Thanks BG
Paragraph 2 says delete the existing google drive folder, then in pars 7 you can now delete the old folder.
Confused.
Confused.
- BillyGoat
- Troll Headbutter
Ignore the delete in 2 :)
- thescruff
I'm Pleased you said that
Takes me about 5 hrs to populate it.
And Dan about 35days
- thescruff
Its showing in raid (D) and it's starting to populate.
Is there one for Dropbox next.
I assume I can just delete the fold in (C) later, or do I need to un-install it from (C).
- thescruff
That work brilliantly BG freed up 25Gb on drive (C) Now sync to a computer in Herts somewhere.
Been looking at the Dropbox, it looks as though I can do exactly the same.
The DB is sync to Nottingham and Herts and you wont believe the sh*t coming my way if I mess up
