Have I done an okay job...?
Posted: Sat Oct 13, 2012 12:40 am
Hey guys
Ive spent the majority of the day sorting out my bath and have finally finished it to what I think is the best I am capable of getting it. What I would like is some suggestions on whether I have done things correctly so for next time I know what to do and what not to do.
A bit of background.
I was installing a full brand new bathroom. Ripped old out, bought new one.
We offered up the bath to the room and adjusted the height then marked where the top of the bath was. We then put a wooden batten in around the top of the bath and took it out of the way.
The wooden batten acted as our tile to point so that the other walls lined up. We put a row of tiles in that were cut so they lined up with the tiles on the other walls and then tiled the rest of the wall etc.
Upon removing the batten and replacing the bath there was a gap where the batten had been approximately 1cm wide from top of bath to the edge of the cut tiles.
We looked at options:
1) use a plastic seal with a 90 degree bend
2) something else.
We bought the plastic seal stuff and I tried to offer it up. We did not skim the walls prior to tiling, and the walls were not true to begin with (mistake I know.. next time this will be done). As such the tiling wasnt 100% perfect (first time ive ever tiled). This meant that the plastic trim simply did not seal it properly. I was going to try and put silicone along the inside of the trim to make a watertight seal but it was having none of it - and it didnt look very nice either. I think the stuff we bought was designed to be installed *behind* the tiles.
So my next solution was to jack the bath up, allowing me to add more support underneath it. During this I put a lot of silicone sealant between the bath lip and the wall and squished it in, hopefully this has created another seal.
Jacking it up and securing it in place resulted in gaps between top of bath and cut edge of tile of 1mm - 3mm.
I sealed around the bath using DOW 785. Left the first seal to cure for 4 hours then placed another seal on top of that to get a better water shedding shape.
I have included pictures of the results.
What I am looking for is some feedback with suggestions of what I could have done better and whether my results are any good - they look okay to me but as this is the first one ive ever done I dont really know what a good job looks like!
Was I correct to do it the way I have done it?
Would the plastic 90 degree trim stuff have been the better option?
Should that plastic 90 degree stuff go under the row of tiles?
Ill be doing another bathroom in the near future so I want to learn as much from this one as possible so any feedback as to what I should have done (although it wouldnt be something I could do now to this bathroom) is appreciated.
My goal is that I learn from this so when I do the next it doesnt take me nearly as long as I wont have to question so many different parts of it and I will have a more general idea of what needs to be done.
Thanks in advance!
*Almost forgot - the corners of my bathroom are tricky - using either a smoothing tool or my finger with washing up liquid isnt working too well - are there any tricks to getting the finish on corners better than I have done (I have noticed in other bathroom corners appear to be the areas that look the worst).
2) something else.
Thanks in advance!
