Halogen Light Fitting - Getting access to bulb
Locked
TheGingerNinja151
Post by TheGingerNinja151 »
Good morning everyone, this is my first post and I'm a bit of a DIY newbie.
I have a halogen light fitting in my bathroom and the first one has gone and needs replaced. Unfortunately I can't even get the bulb out the socket!
The picture below shows the fitting, I'm fairly sure that the inner ring needs to come off before I can get the bulb out but it's fixed tight and doesn't move. Does anyone have any bright ideas? (Apologies for the awful gag)
Rich-Ando
Pro Tradesman
Has thanked: 135 times
Been thanked: 304 times
Re: Halogen Light Fitting - Getting access to bulb
Post by Rich-Ando »
:welcomeuhm:
normally the inner ring just twists anti clock to release it. if it's stuck then use a bit of force.
TheGingerNinja151
Thank you so much, I had to get stuck in with a little bit of brute force.
I can now get to the bulb but can't get it out the fitting!
I hate halogen bulbs and lights.
Locked
Return to “Lighting”
