Does anyone know where I can buy a large piece of thin sheet metal 1200mm x 900mm? Needs to be less than or up to 1mm thin ideally.
Thanks.
London based sheet metal sellers?
- Has thanked: 77 times
- Been thanked: 335 times
Re: London based sheet metal sellers?
Some motor factors stock plain sheet steel in the thickness you want, the sort of place that sells panels etc should sort you out...
I gather you don't want galvanised sheet?
If not, have a look here-
http://www.mig-welding.co.uk/metal-suppliers.htm
Might be one local to you....
- big-all
- Pro Carpenter
- Has thanked: 735 times
- Been thanked: 2339 times
google search
http://uk.loadedweb.com/cities/london/l ... wholesale/
