kitchen unit/door not level
Locked
guitardedleon
Has thanked: 10 times
Been thanked: 17 times
Post by guitardedleon »
I have a few carcasses here for what will be an added on section in one of my properties.
carcass went together fine
door all hung bla bla.
however the top of the door will not stay straight
it sort of drops off on the side furthest from the hinges.
and the back peice of hardboard wont sit 100% in on the hinge side
Ive included pics.
no matter what adjustments I make it will not stay..
then by accident I leant on the carcass toward the back and realised that if you pulled the carcass slightly to one edge the door would align and the board would sit in.
any ideas?
ive checked for level etc adjusted hinges.
Door out of line:
door out of line.jpg (93.82 KiB) Viewed 2003 times
board standing proud:
board sticking up.jpg (78.55 KiB) Viewed 2003 times
cross view to show how opposite side of board is sat flush:
cross view.jpg (94.7 KiB) Viewed 2003 times
shows, when pulling the carcass toward the hinge side the door aligned correctly:
door lined properly.jpg (88.37 KiB) Viewed 2003 times
show, when pulling the carcass toward the hinge side the board sat correctly:
board sat flush.jpg (98.17 KiB) Viewed 2003 times
Has thanked: 736 times
Been thanked: 2341 times
Re: kitchen unit/door not level
the back panel will be square the cabinet should be lined up to match it and fixed/glued to it
speed
Has thanked: 35 times
Been thanked: 257 times
Post by speed »
you need to square up the unit and nail/screw the back panel in to hold it square
guitardedleon
Cheers both
I dismantled the unit
And re assembled it around the panel
Its improved slightly
But as soon as the door is hung it pulls it out of square
Not as much as before but still does pull it out...
As though the door is too heavy?
wine~o
Has thanked: 1415 times
Been thanked: 4024 times
Post by wine~o »
Might be an idea to add a few of these..
http://www.diy.com/nav/fix/hardware/joi ... ing_blocks
To re-inforce the carcass, (making sure it's square)
If that doesn't work then heavier duty hinges are called for..
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
Fix it to the wall before you hang the door, fix all (any) adjacent cupboards together.
Locked
Return to “Kitchen Fitting”
