large pan
russellsmiler
large pan
Post by russellsmiler »
Hello to all, I am a newbie here, and hope i am at the right place?
I have been trying without success to purchase, a giant cooking pan, (recently was on holiday and at a market there was a stall cooking a curry in a pan that was massive)
Picture below!
I would like to have one made, any ideas of metal used, thickness, how made??
Russell
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Re: large pan
Post by ayjay »
Tesco have a large (60cm) paella pan, I haven't found any really large Woks (in the UK) with just a quick look on-line (32cm the largest I saw for sale).
http://www.tesco.com/direct/huge-paella ... s_311-0703
There's some large Woks for sale in the USA. Up to 30" - 760mm
http://www.foodservicewarehouse.com/tow ... 74508.aspx
Unless you need something a specific size it will be a whole lot cheaper to buy ready-made.
Has thanked: 814 times
Been thanked: 3508 times
Re: large pan
I would think that that pan was made up out of sheet metal welded together as a one off project and would not be available to buy off the shelf so to speak. An ordinary sized pan is normally stamped out on an hydraulic press. It would weigh a lot and you would need handling equipment to move it anywhere. Then you would have to meet 'elf and safety if you wanted to do a similar style street event here. Some silly sod would trip and fall in it to get the compo.
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Re: large pan
Post by kellys_eye »
Drop into your local Asian Supermarket and check out their wares. I've seen some 'massive' pots, pans and woks but nothing quite on the scale your photo shows. Check around for an old (metal) satellite dish - some older systems (C-band) had dishes up to 6ft across.
Has thanked: 735 times
Been thanked: 2339 times
Re: large pan
heston had quite a big one yesterday
http://www.channel4.com/programmes/hest ... l-food/4od
Hitch
Has thanked: 77 times
Been thanked: 335 times
Re: large pan
Post by Hitch »
How big do you want.......?! :wink:
Thats probably made from 2 parts, maybe 3.
A large disc, then the sides made from 2 parts i'd guess. Looks like a seam on the far left of the picture.
Materials, lots of pots are stainless, with an aally base, but i think a lot of Woks are just plain steel. That one looks like it maybe steel.
To be honest, the main limiting factor, is the sheer size and ease of moving it about....and i suppose getting a decent even heat under a large area.
Bikergirl
Has thanked: 100 times
Been thanked: 133 times
Re: large pan
Post by Bikergirl »
Look local to where they're from, ie chinese websites, or catering supplies. Biggest I could find in a quick look was 78cm http://www.gasburner1972.com/products/i ... r-wok.html
I used to live in Spain, and 1.2m paella pans are considered large, but fairly ordinary in a professional kitchen.
Huge would be about 3-4m across.
Bikergirl
Re: large pan
Post by Bikergirl »
Got carried away looking at paella pans and found this http://www.expomaquinaria.es/paelleras- ... es925.html
mouth 160cm, base 130, height 30, 4 handles, 2mm steel, 462l capacity. Price, eyewatering £1020ish (1053 euros + VAT at 21%)
russellsmiler
Re: large pan
Thanks for your replies.
I have seen paella pans, the web is awash with suppliers of them.
Thanks for the link Biker girl, the pans you have lnked are just what i was thinking!!, However the price is eye watering!!
Going to seek having one made!!
Anyone here kwno what weight 3mm steel is per M2, or even calculate the weight of pan
I am roughly going for size as sketch below
Anyone here carrying the skills to maybe have a go at this???.. funds available!!
kellys_eye
Re: large pan
3mm mild steel is 23.55kg/sq metre.
A flat bottomed pan with a lip should be relatively easy to manufacture. Aluminium might be a better option. You might even find a panel beater who could 'knock one out' (giggidy) for you.
Hitch
Re: large pan
Post by Hitch »
Where are you based Russell?
russellsmiler
Re: large pan
Can see that this will weigh in at 37.2 KG, HSE say thats definetly a 2 person lift, would be good and sturdy out of 3mm
Hitch I am based in Mid-wales, are you potentially a manufacturer, if so good.
A final design would be to have the sides sloping out at about 70 degrees, handles, and have thought about some eylets for suspending by chain of a tripod, possibly would like a ball hammered finish.
Enjoying this!!
Russell
russellsmiler
Re: large pan
Hitch
Thanks for message, I am considering your proposal, Will have to think how i get it from somerset!
Unfortunately it seems i cannot send personal messages as yet, it says i am to new and havent participated on the forum enough to do so.
DTWCeramics
Has thanked: 13 times
Been thanked: 43 times
Re: large pan
Post by DTWCeramics »
russellsmiler wrote:Hitch
It's cause UHM doesn't like you!
JK, it's just to stop spambots & companies like myself just messaging people saying " BUY OUR STUFF "
Saw a cooking program on the beeb the other night where somebody went to a traditional muslim wedding, they had a huge pot and had been cooking a huge meat curry for around 8 hours, looked like the guy was about to keel over and die from the strain of stirring it. Looked like it tasted awesome though.
Good luck with this pan if you do ever get one!
Cheers :thumbleft:
Matt
Hitch
Re: large pan
Post by Hitch »
Another way about it would be to have a 'dished end' these are readily available, and don't cost the earth.
Perhaps a bit more heavy duty than you want, and more of a wok shape. They normally have a hole in the middle too, so would need welding up, and then the whole thing blasted/polished.
http://www.hvacwarehouse.co.uk/ellipsoi ... ished-ends
Either that, or contact a metal spinning firm, and ask for a price to do one.
If you wanted a square one, thats much easier :lol:
