Tiling on 9.5mm plasterboard
custom made
Has thanked: 10 times
Been thanked: 8 times
Post by custom made »
One more question
The walls in the bathroom are 9.5mm plasterboard that I will be tiling. The tiles are 25x33cm and will go from floor to ceiling.
My question is, would the plasterboard take this load and in particular in the shower area as there will be a power shower there?
Andy
DuffMan
Has thanked: 5 times
Been thanked: 3 times
Re: Tiling on 9.5mm plasterboard
Post by DuffMan »
Maybe safer to skim the shower area first then sbr before tiles. The rest should be fine
haveagohero
Has thanked: 2 times
Been thanked: 28 times
Post by haveagohero »
Don't skim it, un skimmed plasterboard can support more weight than skimmed.The maximum weight plasterboard can support is 32kg/m2, skimmed plasterboard can support 20kg/m2. You will need a tanking kit for the shower area (Bal WP1 or similar). I would use a good quality cement based bagged adhesive and flexible grout. Hope this helps.
wine~o
Has thanked: 1414 times
Been thanked: 4019 times
Post by wine~o »
haveagohero wrote:Don't skim it, un skimmed plasterboard can support more weight than skimmed.The maximum weight plasterboard can support is 32kg/m2, skimmed plasterboard can support 20kg/m2. You will need a tanking kit for the shower area (Bal WP1 or similar). I would use a good quality cement based bagged adhesive and flexible grout. Hope this helps.
Does 9.5mm plasterboard really support that weight ???
DuffMan
Post by DuffMan »
Plaster board does support more weight than skimmed board . You should maynbe think abouy usimg tile backer boards you just tile straight over them
tictic
Been thanked: 23 times
Post by tictic »
9.5mm plasterboard!!!!!!!
Don't even use that on ceilings anymore.....
Change to 12.5mm backer boards or 12.5mm moisture resistant board.
9.5mm ffs... :roll:
DTWCeramics
Has thanked: 13 times
Been thanked: 43 times
Post by DTWCeramics »
tictic wrote:9.5mm plasterboard!!!!!!!
9.5mm ffs... :roll:
12.5 is a bit excessive, I'd say 10mm would be good for the job. Marmox/****/Hardi/Jacko etc would be good choice for the situation
Matt
tictic
Post by tictic »
9.5mm ffs... :roll:
Always myself tell people 12.5mm......
Then when marrying boards in outside the wet area you won't have problems levelling boards off...I.e. 10mm to 12.5 mm....unless off course the room is a complete wet room.
Andrew
Has thanked: 3 times
Post by Andrew »
So are you lot saying that it's best not to skim over plasterboard before tiling?
If so, do you have to fill the butts (oh err) and corners first?
Or does that get done when tanking?
tictic
Post by tictic »
Never skim plasterboard if your fixing tiles...
1. You then need to wait for the finish plaster to cure...
2.your weight limit will only be 20kg per m2....unskimmed 32kg per m2...
In your first OP...you mention ...power shower?....is it a power shower or thermostatic shower...
Won't be electric...?
tictic
Post by tictic »
Andrew wrote:Hi,
Looks like you have hijacked a post....
Please keep your questions to the post you a put up......then no one(me) will get confused...eh...ta :thumbleft:
tictic
Post by tictic »
custom made wrote:One more question
Andy
Custom made....
You say power shower....if so the grout,if your normal grout won't last long with a power shower hitting it....and that 9.5mm p/board will turn to weetabix in no time ....
For power shower you will need an epoxy grout....
Return to “Tiling Forum”
