Tileing onto Epoxy Resin
DIY-RICHEY
Post by DIY-RICHEY »
Hi, I will be putting down Ball F75 Liquid DPM onto a newly screeded floor. Just wondering if you can tile straight onto Epoxy Resin once its fully cured?
Thanks :thumbright:
DIY-RICHEY
Re: Tileing onto Epoxy Resin
*Tiling :tool:
tictic
Has thanked: 5 times
Been thanked: 23 times
Post by tictic »
The new screed...does this not have a dpm under it??
What type off screed is it...how thick is it??
The new screed will need to cure before a liquid dpm is applied..
You will need to prep the screed before pouring the dpm...I.e.remove latiance and if smooth,.. key it up...
Apply a primer to screed then follow mfr inst..
Then after dpm set(two coats)...applied in opposite directions....apply a primer before tile fixing...your adhesive mfr will specify correct primer..
Also if there is water ufh or elect ufh...you can't use a liquid dpm..
Return to “Tiling Forum”
