Drilled holes aren't circular
Rustyy117
Post by Rustyy117 »
:welcome:
I'm trying to drill some 10mm holes in 1mm thick aluminium, I first drill a 4mm pilot hole and then use a 10mm HSS standard metal working drill bit but the holes are really misshapen :wtf:
Here's an images to show what I mean (sorry for the low quality)
So my question is, what can I do in order to get perfect (or near perfect) 10mm holes?
Thank you! :cheers:
BillyGoat
Troll Headbutter
Has thanked: 386 times
Been thanked: 796 times
Re: Drilled holes aren't circular
Post by BillyGoat »
Was the drill skipping around?
You could clamp the metal between TWO bits of wood, drill through the top wood, straight into the metal - it will act as a guide and stop your bit skipping.
Make sure the bits are nice and sharp too....
BG
Has thanked: 48 times
Been thanked: 2604 times
All is not lost. You can still make them round.
Cone cutter
Rustyy117
Post by Rustyy117 »
BillyGoat wrote:Was the drill skipping around?
BG
Hey
No, it wasn't really skipping but it was vibrating quite a bit.
The drill bit should be sharp as its brand new.
I think I'd find it differcult to be millimetre accurate if I were to drill through a piece of wood and then into the aluminium :sad:
Any better drill bits for this type of work, or perhaps a 10mm hole saw bit for metal work?
Rustyy117
Post by Rustyy117 »
someone-else wrote:All is not lost. You can still make them round.
Cone cutter
Hmm... cool I'll look into those.
Thanks :thumbright:
SCREWFIX £21.89
You can also get "stepped" cutters, but they cost considerably more.
merlin50
Has thanked: 7 times
Been thanked: 37 times
Post by merlin50 »
A pillar drill is best, but without one step up in sizes drilling a bit at a time and do not use cheap drills
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
Grind the angle of the drill much shallower if you have a bench grinder.
Slow the speed of the bit down too I expect.
Rustyy117
Post by Rustyy117 »
merlin50 wrote:A pillar drill is best, but without one step up in sizes drilling a bit at a time and do not use cheap drills
Yeah don't have a pillar drill so will try those cone drill bits
Rustyy117
Post by Rustyy117 »
Hitch wrote:Grind the angle of the drill much shallower if you have a bench grinder.
Unfortunately I don't have access to an angle grinder, I don't do much DIY :/
I will slow down the drill speed though :thumbleft:
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
Don't look as though you drill right though
Wee Eck
Has thanked: 16 times
Been thanked: 28 times
Post by Wee Eck »
Drill a 4mm pilot in the wood and metal separately, align them (using the bit), clamp them then drill through all three with the 10mm?
