Running hood duct through chimney
Locked
Frankn
Post by Frankn »
I want to add ducting to my existing cooker hood - currently just carbon filter and straight into kitchen.
Problem is the only reasonable route is along cabinet tops and then through external wall. I would be confident to attempt this if it were not that the external wall is a chimney (1906 terraced house with disused chimney on rear wall).
Stack (shared with neighbour) is still present but closed off at top (no chimney pots etc). I don't know how/if this is ventilated - fireplaces already closed off when I bought house.
Can I pierce both internal and external walls of chimney to run ducting through? What other possibilities could I try?
Thanks.
Frank.
JohnKay
Has thanked: 7 times
Been thanked: 36 times
Re: Running hood duct through chimney
Post by JohnKay »
Hi Frank
The problem I see here, is that a chimney breast is not just an inner and outer wall. The flue used by the fire would only be about 9 inches, the rest will be other voids and solid brick.
In practice, this could be done with a diamond core drill, but what if your neighbour decides to open up his side and install something like a wood burner.
Frankn
Post by Frankn »
John,
Thanks for your reply.
I had assumed that there was a larger cavity inside the chimney breast but your reply makes more sense when I think about it.
I got the idea of ducting having seen the Screwfix low profile ducts recently on this site - larger, sheet-metal ducting would be impossible in my situation.
Unfortunately, to reach a true external wall, any sort of duct would have to pass through an area where it could not be hidden from view.
I don't think any present or future neighbour would wish to open the chimney as it just serves the kitchen and the bathroom above, but you never know.
Frank.
Locked
Return to “Kitchen Fitting”
