Remove grout
mole81
Has thanked: 39 times
Been thanked: 4 times
Remove grout
Post by mole81 »
What's the easiest way to trim gone off grout in between floor tiles?
tictic
Has thanked: 5 times
Been thanked: 23 times
Re: Remove grout
Post by tictic »
Eh.....
Trim gone of grout....?.... :dunno: ...?
mole81
Re: Remove grout
Post by mole81 »
Lol,prob my explanation...ive got a larger than the gap between the floor tiles gap behind where the rad pipes enter the room. The grout has gone off hard here and is proud of the tiles. I want to trim this down to put a pipe collar on!
warmadmax
Has thanked: 13 times
Been thanked: 74 times
Re: Remove grout
Post by warmadmax »
If there's room and your careful I'd chisel it out gently,
Though my opinion might change when we can see the pictures,
After you've attached them to the post remember to place it in line,
There is a picture attachment guide ill try and find the link to
Edit - here you go how-to-post-pictures-t254.html
mole81
Re: Remove grout
Post by mole81 »
Heres the pic, hopefully helps!
mole81
Re: Remove grout
Post by mole81 »
any more advice, please? :)
darrenba
Has thanked: 104 times
Been thanked: 490 times
Re: Remove grout
Post by darrenba »
As has been said above, carefully chisel/scrape it down.
mole81
Re: Remove grout
Post by mole81 »
Ok thanks,what type of chisel shoukd i use?
darrenba
Re: Remove grout
Post by darrenba »
An old wood chisel would be OK.
royaloakcarpentry
Been thanked: 621 times
Re: Remove grout
Post by royaloakcarpentry »
Looks wet around the pipe and also seems like the tile is cracked, unless it is a hair on the floor.
mole81
Re: Remove grout
Post by mole81 »
It's definitely not wet, the grout hasn't gone off the same colour consistently in some places oh and that's a hair lol
haveagohero
Has thanked: 2 times
Been thanked: 28 times
Re: Remove grout
Post by haveagohero »
Did you tile the floor yourself? that cut out is shocking at the very least there should be a piece of tile in behind the pipe not just packed with grout
root
Has thanked: 168 times
Been thanked: 173 times
Re: Remove grout
Post by root »
that's not very helpful line of interrogation there hagoh.
As Darren suggests i would carefully and slowly chisel/scrape down and remove excess.
- Dave
mole81
Re: Remove grout
Post by mole81 »
haha no i didnt do it myself, I get your point though and one of the reason im putting the pipe collars on!
haveagohero
Re: Remove grout
I would have the tiler back to sort it out personally but as others have said use a narrow wood chisel and go carefully
Return to “Tiling Forum”
