General questions (tiliing is confusing!!)
Andrew
Has thanked: 3 times
Been thanked: 3 times
Post by Andrew »
I thought I was all sorted in my tiliing decisions - I was going to get BAL Primer, Bal White Star, and BAL Microflex (basically this is because the BAL technical team told me). This is for above a bath.
Then I saw the prices and reviews of Mapei and now I'm confused. Also, the more you read the more you find out loads of other stuff! Ie everyone recommends bagged rather than tubbed, etc.
My questions:
1) Is Mapei better or the same as BAL, just cheaper?
2) Why is bagged adhesive better than tubbed? Especially for ceramic tiles under 300x300?
3) I still haven't decided whether to tank or not (onto plaster (both stud and solid wall). Everyone I know, including myself, have nver used it and never has any issues because we all work to a decent standard. It is quite expensive. Worth it for above a bath with a mixer shower? Also, can you "feather" it out to nothing because I'm not buying two lots of it but I'll be tiling a large wall, some of which won't need tanking at all (does this even make sense?)?
4) Can you mix brands?
5) If I was to go down the Mapei route, what products would I need? They seem to do so many different types of adhesive!
Thanks.
Colour Republic
Has thanked: 263 times
Been thanked: 544 times
Re: General questions (tiliing is confusing!!)
Post by Colour Republic »
Andrew wrote:Hi,
My questions:
BAL and Mapei are both good brands. BAL is only expensive if you buy from Topps at list price
Bagged addy is cement based and sets by chemical reaction, tubbed addy dries by dispersion. Tubbed addy is fine in some situations but it has less going for it than cement bagged addy for many reasons
Tanking isn't really that expensive. Paint on tanking cost anywhere from £35-£70 depoending on brand and covers around 5 sqm meters which is normally enough from most wet areas in an average bathroom. It is only applied 1-2mm thick so no issues with tanked to non-tanked areas. £30-£70 is a small price to pay to protect the substrate in a wet area
Do you mean a primer from one and an addy from another? If so then no it is not advisable to do so.
Depends on the tiles and what you are tiling but in general a flexible adhesive, standard set to give you a bit more time. Although as I say that will depend on your tiles/substrate/area
Thanks.
Andrew
Post by Andrew »
Good answers, ta.
I was thinking Mapei tanking and the BAL adhesive. But i'll probably stick to one or the other.
Who else sell BAL stuff? Should I be looking at small independant shops or something? I don't buy stuff like this online.
Thanks.
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Topps do Bal, don't know who else. Topps also do there own brand which is nice to work with.
If you have a Nicholls and Clarke near you www.ncdirect.co.uk they also do very good adhesives, tiles and grouts as well as tanking kits.
Return to “Tiling Forum”
