First up is the biggest ensuite with bath wc and basin.
'er indoors has chosen the tiles. Big heavy 310x450 ceramics with heavy relief dado tiles and a smattering of small stick-on individual diamond relief tiles (stick-on or cut into main tile). Total 16sqm to ceiling with 2 largest walls stud skimmed and 2 smaller walls brick/block, hardwalled and skimmed.
I was going to pva, looked here and screwfix and stopped dead.!
The new plaster sucks like mad and so i definitely need a primer.
Aquapanel would have been an option but not now the coving is on and some fittings are in. What about flat bedding waterproof adhesive? If not, and using a notched trowel, what depth notches?
Where do i start? Batten across at bath level and work up from there with a bit of measuring first to avoid little fillets into the corners and ceiling?
2mm spacers? silicone gaps to the fittings? The plumbing is boxed in on one side at floor level up to about 200mm x 150mm to wall and the floor will be water-proof carpeted. so carpet the upstand of the box or tile to floor?
Any advice will be much appreciated,
cheers,
Peter
