uPVC window handle won't close window properly, how can I fi
The handle on one of my uPVC windows won't turn to keep the window shut. The window doesn't form a seal against the frame so it is getting cold in here! I've noticed that there's a small metal pin sticking out of the handle fitting. On another (working) window in the house, this metal pin is flush with the handle fitting. Here are some links to pics for comparison:
Bad window:
Good window:
What is this metal pin? Is it kind of safety catch? If so, how do I release it?
If the pin isn't the problem, how can I get this window to close properly? There are no screws to undo the handle. The locking mechanism seems to be via two sliding bolts on the bottom edge of the window.
Failing getting the window working, how can I seal the gap between the window and the frame to stop the heat getting out?
Thanks for reading.
Bad window:
Good window:
Thanks for reading.
- Someone-Else
- Has thanked: 47 times
- Been thanked: 2575 times
Re: uPVC window handle won't close window properly, how can
Wide sticky tape. I only wish I was joking, but it does stop the cold winds.Epimenides wrote:..........Failing getting the window working, how can I seal the gap between the window and the frame to stop the heat getting out?
Thanks. I can't get the pin to move at all. Looks a though I'm going to have to seal the window up with cardboard and tape.
- Has thanked: 40 times
- Been thanked: 51 times
Get a man in....
Seriously though, I don't think the pin is making any difference here, yes it probably should and would have been flush, so try and get it back in, but I doubt that is why it won't close.
Does the handle go to the closed position or even move when the window is open?
If not you have a problem and may well need to replace or repair the moving parts. If it moves when open, then make sure nothing is in the tracks on the frame to obstruct the bolts etc when you try to close it ....
Thanks for the reply.
No movement at all from the handle, even when the window is open. Tried tapping the pin back in but nothing doing.
There's a good deal of rust all over the moving parts - I suspect it's time for them to be replaced.
- Has thanked: 32 times
- Been thanked: 805 times
never seen handles like that before. but i should imagine the part that attaches to the window will be a cover hiding the screws. you will likely have better luck if you can get it off and have a look then.
- Has thanked: 2 times
- Been thanked: 6 times
hi the pin is to stop the handle on the spindle I guess the long part on the frame will
be a cover plate remove this and there should be some scews . either the handle will be at fault worn spindle or the window gear ( espag gear)
- Has thanked: 68 times
- Been thanked: 10 times
I've just solved a similar problem with some of my uPVC windows in that they
were not closing flush with the frame....
Checking the multiple pivot hinges showed there was no real issue with them,so
I sprayed WD40 all over the hinges after cleaning as much dust and dirt as I could.
That had a dramatic effect, all the windows now settle onto the frame seals properly.
