Conservatory curtain poles
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
My sister wanted some simple rails for her conservatory, not full on curtains, only for voiles.
I messed up the pics, so not great quality or quantity :oops:
These are the brackets-
The back section comes off, to allow invisible fixing, one grubscrew too lock the two section together, the other to lock the rail in position.
The rails are 10mm diameter solid stainless steel.
I bought it in 6m lengths, then rough cut it for each section of the shape.
Bar and brackets 304 stainless steel.
Final lenghs were decided after fitting the brackets.
Ends cut and polished to the same dull polish finish as the main bar and brackets.
Long rail in position.
Cut with a thin disc, then polished with a reca polymop, heat discolouration then removed with a coarse diamond block, to match the grit of the polish.
Total of 6 individual rails, about 11.5 metres.
panlid
Been thanked: 1 time
Post by panlid »
i like the idea of these. i have never seen curtains in a conservatory, always blinds.
what screws did you use?
you do know there is a middle spine in the upvc and if your screws are about 2" long they will get it.
Hitch
Post by Hitch »
Went for stainless ones, coarse thread like you recomended.
Found some quality Spax ones :thumbright:
They all screwed in nice and tight, some must have gone into the ally behind :thumbright:
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
You don't get quality like that in the shops :wink:
Good work :thumbright:
Hitch
Post by Hitch »
Quite right Chez, made to measure. I wonder how much something like that would cost to have done :scratch:
Tryanything
Been thanked: 4 times
Post by Tryanything »
Nice job Hitch
In London they would charge £300-£400 for that posibly more
There would be less trouble in the world
if l had not had six daughters
blakes
Has thanked: 6 times
Been thanked: 9 times
Post by blakes »
Nice work. The pic of you using the angle grinder made me cringe a bit though!
Only-Me
Been thanked: 3 times
Post by Only-Me »
panlid wrote:i like the idea of these. i have never seen curtains in a conservatory, always blinds.
There for the hanging baskets :roll:
Hitch
Post by Hitch »
blakes wrote:Nice work. The pic of you using the angle grinder made me cringe a bit though!
Only a polishing mop in there :wink:
yourweb
Post by yourweb »
Those look very nice. What kind of design did you take them off of?
Chrispops
Post by Chrispops »
New to the forum, can I ask where the curtain rail bracket’s were bought from?
Has thanked: 47 times
Been thanked: 2571 times
Chrispops, you can ask but the OP stopped posting Nov 21*, and he made this post 15 years ago (2007) so I doubt the place he got the brackets from (If he can remember) is still trading.
On any forum, hi-jacking a thread is never a good idea, always best to start your own. :-)
*He does browse occasionally.
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 566 times
Post by moderator2 »
Someone-Else, Hitch was last active on here less than 2 weeks ago, which is why I haven't locked the thread.
Return to “Show Case Gallery”
