Makita disc cutter, cuts out
Find power tool manuals in here.
Locked
blb
Has thanked: 13 times
Post by blb »
Hi all
Borrowed a friends Makita petrol, 2 stroke, Disc cutter, used to work ok, the other day it started fine and ran normal on idle but as soon as i start to cut (Paving stone) it dies, help please
Handyman in Sussex
Has thanked: 40 times
Been thanked: 51 times
Re: Makita disc cutter, cuts out
Post by Handyman in Sussex »
blb wrote:Hi all
Was it warm or cold when you went to cut with it?
Let it warm up a bit and then give it a few bursts on the trigger, longer each time and slowly increasing the revs, then give it a longer burst at about half revs or so to warm the engine, then give it full blast and do the cut. It sounds like it's stalling because you're opening it up too much before it's warm.
Good luck,
Jonty
These users thanked the author Handyman in Sussex for the post:
blb
fin
Has thanked: 32 times
Been thanked: 805 times
Post by fin »
filters? our stihl saw did this if the filters were clogged up
These users thanked the author fin for the post:
blb
blb
Post by blb »
Hi
Thank you both for your reply, I did as Handyman sugested with no luck. Fin was spot on, it was a foam "air filter" cloged up it now works fine (So far)
Thanks again.
fin
Post by fin »
i used to knock the foam filter about to get the dust out of it and if it got a problem starting and the paper filter needed cleaning id take it to a garage and get it blown out with an air line.
Locked
Return to “Power Tool Manuals”
