Hardie backer board
RobinClay
Has thanked: 27 times
Hardie backer board
Post by RobinClay »
I have ripped out ensuite and am doing a DIY refit.
The old ceiling was partly tiled, and also partly sloping, so I took off the tiles - and the plasterboard behind them.
I have replaced the plasterboard with Hardie backer board.
Should I now to skim this and paint it ?
Or should I just tile straight onto the backer board ?
I'm inclined to do the first, I don't think tiling is necessary.
What do you think / what would you do ?
Oh, and there are small gaps in the joints. These would be filled either with skim plaster or with tile adhesive - is that OK ?
wine~o
Has thanked: 1414 times
Been thanked: 4019 times
Re: Hardie backer board
Post by wine~o »
pics would be a bonus, I'd be inclined to say don't tile unless it's going to get wet (Showerhead spray or similar)
RobinClay
RobinClay
Post by RobinClay »
The sloping ceiling starts six foot (1830) above the floor, i.e. about 69" (1755) above the shower tray floor. This would (usually) be below the shower head, but not entirely immune to re-bound. But at a 45 degree slope, water would drain/drip off relatively quickly. Probably.
wine~o
Post by wine~o »
Assuming the slope isn't going to be getting a significant amount of water. then leave it un-tiled, just make sure that where the tiles meet the slope there is a bead of silicone to prevent water ingress....
RobinClay
RobinClay
Post by RobinClay »
Thanks - and skim ?
RobinClay
Post by RobinClay »
... and here are the pix...
The ceiling joist running parallel to the right hand wall is higher than the others, so the plasterboard has been bent to fit.
The cut line at the top of the vertical part of the wall is 1830 above the floorboards.
First piece of Hardie backer board installed.
Tiles and plasterboard removed from ceiling over shower.
Old shower removed.
Old shower removed.
Before demolition, but new loo installed.
Before demolition, but with the old loo removed.
Return to “Tiling Forum”
