Help with frame for tank
afcbob
Post by afcbob »
Am away to build a big fish tank in to my wall 6 x 2 x 2ft 12mm think glass ways about half ton fill i think. i need help noing how best to do this is size of wood? i was think 4x2"
I also would like to no what joints to use for this. am on a 1st floor flat so need the load spared over the floor
Any help would be great.
This will be the 1st of a few post on this project.
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Hi afcbob,
welcome to the forum.
You are right, if my calculations are correct it will weigh roughly 1/2 Ton, that is some weight for an upstairs flat!
I think it might be a good idea to consult a structural engineer before you go much further as half a ton is a lot of weight to be concentrated in such a small area of an upstairs flat, he will advise you best.
On the construction side I think you should consider incorporating some large steel brackets that bolt to a solid wall, to take some of the weight. You could conceal these with your wooden frame. 4 by 2 should be strong enough as long as it is designed correctly, I would use coach bolts, with timber connector washers between the two pieces of timber that are being joined then a couple of large penny washers and a nylon locking nut. Spreading the weight across as many joists as possible is essential.
I'd check with a structual engineer first, to be on the safe side.
dirtydeeds
Craftsman Carpenter
Been thanked: 1 time
Post by dirtydeeds »
afcbob, from your post, it would seem that you need a bit more detail and some idea of weights, the weight of glass is not the problem
you need to be more concerned about the weight of the water, help is at hand. 1 litre of water weighs 1 killogramme
IE a cube of water 100mmx100mmx100mm weighs one killogramme
so re meausre your tank in metric dimensions then you can accuratly weigh the water weight JUST my measuring the tank size
dirtydeeds
Craftsman Carpenter
in simple terms your tank is 6 foot X 2 foot x 2 foot
so the weight of water (if illed to the brim) is 6 foot = 1.22m, 2 foot is 610mm
so 1.22x.61x.61 = .45 cubic metres
.45 cubic metres = .45 tonnes =450 killogrammes (because 1 cubic metere of water weighs 1 tonne)
dirtydeeds
Craftsman Carpenter
from an american site glass 13mm thick weighs 6.7lb per square foot
SO 12mm thick glass weighs 6.7lb/13mmx12mm = 6.18lb/square foot
NOW convert lbs to kilos 6.18 lbs = 2.8kilos
SO 1sq foot of 12mm glass weighs 2.8Kilos
NOW convert sq foot to Sq metres .305x.305= .0915sq metres
.0915sq m, * 2.8kg = 0.199kg/sq metre
SO
tank base 6ftx 2ft =1.22*.61= 0.74m2
tank front and back 1.22*.61*2 = 1.49m2
tank ends .61*.61*2 = .74m2
so glass weight= .74+1.49+.74= 2.97sq metres x .199Kg = .59Kg
dirtydeeds
Craftsman Carpenter
SO adding the lot together
450 Kg of water (filled to the brim) plus .59Kg of glass
total weight = approximatly 451 Kilogrammes
NOW
on four legs 451Kg / 4 = apprximatly 113Kg per leg
on six legs 451Kg / 6 = approximatly 75 Kg per leg
remembering always that this is based on the tank being filled to the brim
NOW
the tank is never filled to the brim so the weight will be reduced, but the tank will have a gravel base in the bottom of some sort
gravel weighs somewhere under 2 tonnes per cubic metre
it is safe to assume that that the tank is only filled to 2/3 of the total capacity SO no adjustment has to be made for the weight of the "bed" of gravel
SO
it is safe to assume with some safety margin that each of four legs of a tank this size will take 113Kg of load (and 6 legs will each take 75Kg)
THIS ASSUMES YOUR TANK DOES NOT HAVE A WAVE MACHINE, IN WHICH CASE I SUGGEST YOU CONSULT AN ENGINEER
FINALLY
check the mathematics before you use them but it all looks right to me
