old kitchen unit door hinges
Locked
peterpan01
Post by peterpan01 »
hi,
i have taken off the old plastic hinges to replace them with metal soft close ones. However i found much to my annoyance after buying the new ones, that the plastic ones have left a larger hole than the new ones to screw into(the carcass of the unit that is not the door). So i cannot screw the new hinges onto the unit because the hole is too big!
what can i do? no nails? woodfiller?
any help would be great
cheers
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Re: old kitchen unit door hinges
Post by ayjay »
Something like this, if it's for the carcass.
http://www.amazon.co.uk/CUPBOARD-DOOR-H ... 6040126302
prem
Been thanked: 17 times
Post by prem »
cant you use the old screws in the new hinges or buy the grub screw to fit the hole 5mm . or is the hole bigger than 5mm?
Has thanked: 736 times
Been thanked: 2341 times
ayjay wrote:Something like this, if it's for the carcass.
other sources woodfit
http://www.woodfit.com/product_info.php ... right+Zinc
Locked
Return to “Kitchen Fitting”
