Installing toilet directly on top of porcelain floor tile
gocsan
Has thanked: 8 times
Been thanked: 2 times
Post by gocsan »
Morning all
I'm about to tile my bathroom floor with porcelain tile with the toilet removed beforehand. Just thinking ahead, do I need to put some kind of putty, or any rubber material in between the tiled floor and the toilet to act as a cushion? Or can I just put the toilet directly on top of the tile and screw it on?
Many thanks
wine~o
Has thanked: 1414 times
Been thanked: 4019 times
Re: Installing toilet directly on top of porcelain floor til
Post by wine~o »
You could bed it down on a bead of silicone. Hope you've got the necessary to drill through the porcelain tiles...
BillyGoat
Troll Headbutter
Has thanked: 386 times
Been thanked: 796 times
Post by BillyGoat »
wine~o wrote:You could bed it down on a bead of silicone. Hope you've got the necessary to drill through the porcelain tiles...
Hammer?
wine~o
Post by wine~o »
Hammer off...
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Just sit the krapper on the floor and mark out for screw positions. Armeg porcelain drill bits are extremely good and will only set you back about £25 for an 8mm bit.
Don't sit the krapper on silicone as you will be left with a right pig of a job should you need to move it out because of a leak etc etc.
You want stainless steel or brass screws.
Return to “Tiling Forum”
