Playhouse base
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Playhouse base
I spent a few hours today finishing off this base for a playhouse. Angie’s uncle makes sheds, summer houses and garden offices for a living so she has ordered a playhouse from him for the garden.
Because the garden is not very flat she decided to put it at the bottom, but the ground is often very wet, so I started to make a base a couple of nights ago. I was really struggling cutting the 8*2 inch timbers as I sold my Dewalt chop saw a few years ago as I thought I would never need it again. I was cutting the timber using a circular saw but it was difficult to cut, so after making the initial square and fixing one joist in the centre I decided to stop the job until I got another Mitre saw.
I went to B&Q this morning to get a post hole digger and noticed they had a sliding evolution mitre saw on special offer at £99
Although the saw is not accurate it made cutting the joists and noggins very easy!
The base is 8ft by 8ft and is made from 8” * 2” tantalised timber. It’s fixed to 6 posts which are just knocked into the ground using a post knocker. Five of the posts are 5” * 3” tantalised timber, which have been knocked in as far as possible, then cut off flush with the top of the frame (one post was knocked in all the way). On the middle joist I used a split tantalised post, but this will never be seen once the playhouse is in position. I’ll post a picture of the playhouse once it has been built on about the 15th May
- These users thanked the author ultimatehandyman for the post (total 2):
- happy handyman • nick200
- Rating: 14.29%
- EJJ150847
- Has thanked: 35 times
- Been thanked: 188 times
Re: Playhouse base
You need a BIGGER 'man shed' than 8x8, tell Angie it's not big enough for two girls, double the size.
Then move in your self, only way you'll get any peace.
I had the best idea, I went to the West Indies for 6 months and the far east for 9 months when our two girls were born.
John
John
- These users thanked the author EJJ150847 for the post:
- ultimatehandyman
- Has thanked: 177 times
- Been thanked: 135 times
Re: Playhouse base
Thanks for posting the picture and instructions, I need to do a shed base for my sister in law, so your base should fit the brief....Thankyou !
- These users thanked the author happy handyman for the post:
- ultimatehandyman
Re: Playhouse base
Just a couple of questions,
I was going to dig holes and set the posts in cement, do you think this is unnecessary ?
Did you taper the poles which were sunk into the ground ?
- ultimatehandyman
- Site Admin
Re: Playhouse base
If you have the time setting the posts in some concrete is better IMHO.happy handyman wrote:Just a couple of questions,
I just knocked in the posts as far as they would go, most of them went in between 2-3 feet each, apart from one which went all the way in.
The problem with knocking them in is that they start off straight but if they hit a stone they can twist or lean, which means you have to knock them in and then pack between the post and the frame.
- These users thanked the author ultimatehandyman for the post:
- happy handyman
- nick200
- Has thanked: 409 times
- Been thanked: 222 times
Re: Playhouse base
Thanks for posting.
I may have to do this in our new house so any advice is welcome!
Nick
- ultimatehandyman
- Site Admin
Re: Playhouse base
nick200 wrote:Thanks for posting.
The ground at the bottom of the garden is far from level and is nearly always damp. I chose to use 8 inch by 2 inch timber for the frame as I am not sure of the exact weight of the playhouse. A frame made from this type of timber will be very substantial and should easily take the weight of the playhouse.
I started work on the base on night after work on my own. The footprint of the playhouse is 8 feet square, so I proceeded to cut the timber.
2 Lengths @ 8 foot long
3 Lengths @ 7 foot 8 inches ( these are approximate measurements, I actually deducted 94mm from the 8 foot lengths, which is the thickness of two pieces of the 8” * 2” as they are actually 47mm thick each)
I then nailed these together to make a 8 foot square with one joist running down the centre of the square. I only put one nail in each piece at this point until I was certain it was square, I then used blocks of wood to get the base level, so that the lowest part of the base was about 2 inches away from the soil. I then added more nails to the structure to ensure it was solid. The important thing is keeping it square and level.
The base was then positioned in the correct place and required supporting; to do this I knocked some 5’ 6” long posts that were 5” by 3” using a post knocker. I knocked these in as far as possible, but it’s difficult keeping the posts straight as they stop moving and start to twist if they hit a large stone etc. When knocking in the posts I left a gap of about an inch between the frame and the post, so that I could place packers in the gaps before fixing, this was so that if a post did move considerably it would not move the frame. The posts were cut off flush with the top of the frame using a reciprocating saw.
On the second evening I was fed up cutting the joists using my circular saw, so I only cut one joist that night and fixed it between the existing joist (approximately 2’ centres). On the Saturday I bought a sliding chop saw for £99 and this really made the job easier, my mate also gave me a lift so cutting the last joist and the noggins was easy and quick.
All the joists were fixed at approximately 2 foot centres and so were the noggins, the noggins were nailed straight through from one end and then skew nailed at the other end.
There are three 5 inch by 3 inch posts at the back, two at the front and I knocked a half split post in the centre for good luck.
All timber was tantalised but after fixing it was given a coat of Ducks back to ensure it lasts.
For most of the fixing I used the Dewalt nail gun with 90mm ring shank galvanised nails along with a couple of 100mm long Turbogold XT screws. The noggins were also glued in using external wood glue.
You can see from this second picture how much the ground is out of level.
I hope this explains it well enough
- base.jpg (130.05 KiB) Viewed 6137 times
- nick200
- nick200
Re: Playhouse base
Thanks Chez, that is great
- These users thanked the author nick200 for the post:
- ultimatehandyman
Nick
- Has thanked: 379 times
- Been thanked: 584 times
Re: Playhouse base
Are you going to put a lid on it mate ? I done one similar to yours for a observatory ,and the people who installed it wanted a 18mm ply top fitted
Re: Playhouse base
Chez, thanks for taking the time to explain this......at least no one will be selling this on Alibaba !
- ultimatehandyman
- ultimatehandyman
- Site Admin
Re: Playhouse base
transitboy wrote: Are you going to put a lid on it mate ? I done one similar to yours for a observatory ,and the people who installed it wanted a 18mm ply top fitted
No, I think the playhouse comes with bearers, so it should fit on top no matter which way the bearers run
- transitboy
- ultimatehandyman
- Site Admin
Re: Playhouse base
I forgot to upload the picture of the playhouse
I'll install a deck in front of it when I finish the other deck off
- BANNED
- Has thanked: 216 times
- Been thanked: 1070 times
Re: Playhouse base
Nice job Chez, if I can work out how to put photos on I will add some of the one I done last year for the grand kids.
Just opened myself up for a rollocking from Wino, he did show me a while ago
- These users thanked the author cotswold builders for the post:
- ultimatehandyman
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: Playhouse base
cotswold builders wrote: if I can work out how to put photos on I will add some of the one I done last year for the grand kids.
Scroll to bottom of page
Click on Full Editor
Scroll down again to just below reply box and click on Browse
Find the pic on your PC and click open
Click on Add the file
Put the cursor where you want the pic and click on Place Inline
It's too easy.
- These users thanked the author ayjay for the post:
- cotswold builders
- BillyGoat
- Troll Headbutter
- Has thanked: 386 times
- Been thanked: 796 times
Re: Playhouse base
Don't want to worry you, but your play house seems to have blown away or stolen by Arabs!!!!!ayjay wrote:cotswold builders wrote: if I can work out how to put photos on I will add some of the one I done last year for the grand kids.
It's too easy.
BG
