ROK Sliding mitre saw
You can post and read reviews of all Power tools in here. Tools will be listed by manufacturer, Model number and / or description.please ensure that you put the correct power tool under the correct manufacturer. If the manufacturer is not yet listed then please post in the general part of the power tool review forum.
Stevo77
Has thanked: 4 times
Post by Stevo77 »
Im looking for a sliding mitre saw sadly working to a budget, i have seen this ROK WBS2100 on offer Rok tools have a 2 year guarantee ive never had anything by Rok before so not sure if its a decent brand and worth buying or not.
id be gratefull for any advice from you guys
Thanks Steve
Has thanked: 734 times
Been thanked: 2334 times
Re: ROK Sliding mitre saw
in general you will be hard pushed to find a decent slider below the mid £200 so at £111 who knows
your not connected to plumbworld stevo are you as they are the only ones who seem to be selling them :lol: :lol:
http://www.plumbworld.co.uk/rok-wbs2100 ... 155-130292
Stevo77
Post by Stevo77 »
Lol wish i was i could use a staff discount!
Cheers
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
It's good to know that it's :-
Suitable for Cold Water Systems (NOT Mains)
:wtf:
Stevo77
Post by Stevo77 »
Haha... took a few minutes to work out what you were on about.... i had not spotted that... handy to know tho. Wtf indeed!
Has thanked: 807 times
Been thanked: 3498 times
I notice that this saw has only one slide rail and it is used as a swivel for the tilt too. Most good sliding saws have twin slide rails and the tilt is on a separate bracket. I have to say that the cut accuracy would be dubious as the single rail cannot prevent a degree of twist, especially after it is worn in, which although it will be micro amounts it will lead to inaccurate cuts.
Having said that it is good value and if it is for occasional DIY work then it will probably do all you ask of it.
Stevo77
Post by Stevo77 »
dewaltdisney wrote:I notice that this saw has only one slide rail and it is used as a swivel for the tilt too. Most good sliding saws have twin slide rails and the tilt is on a separate bracket. I have to say that the cut accuracy would be dubious as the single rail cannot prevent a degree of twist, especially after it is worn in, which although it will be micro amounts it will lead to inaccurate cuts.
Yes it is for DIY use not everyday or work, i just want to balance cost with quality in an ideal world id just go with quality over cost but sadly cost is a major factor at the moment.
Steve
Stevo77
Post by Stevo77 »
Would this Clarke one be a much better choice?
http://www.machinemart.co.uk/shop/produ ... +mitre+saw
Steve
I think so, yes. It has the twin rail system with a separate bracket for the tilt which is a better design. I think for the extra £50 it is worth it as the twin rails means there will be far less potential movement and your cuts will have greater accuracy. Bare in mind that saws like this are heavy and you tend to hump them around a bit so they have to be robust to take the knocks. This machine is what I call 'badged' and it is probably a Chinese built machine commonly put out by different companies dressed in their colours and logos. Nothing wrong with that as I have a number of different 'badged' tools from a similar original source and they have all given good service.
You may have to buy a better blade for it at some point but at this end of the market it would be a better buy than the ROK in my opinion. Have a look on Screwfix there are a good selection of sliding saws there within your budget, the Rage ones might be worth a look.
Stevo77
Post by Stevo77 »
Thanks thats a real help ive looked on screwfix ive seen 1 or 2 rage reviews which are not very positive but il look again, thank you again,
Steve
( I knew being on here was good idea, hopefully i can return the favour for someone soon)
Return to “Power Tool Reviews”
