Tiling pattern advice
- Has thanked: 7 times
I'm getting ready to tile the sower cubicle and thought I was going to stagger the tiles (not sure if thats the correct term, but have one tile in the centre then the centre of the tile above in the centre and so on). I've done the floor in a grid format and now I'm thinking it might look stupid. What's normally done, do I copy the floor and go for a grid, or does it matter?
- Has thanked: 39 times
- Been thanked: 621 times
Re: Tiling pattern advice
Cheers. Wee pic of the floor finished, just hope it lasts!!
- 20130520_200220_resized.jpg (264.14 KiB) Viewed 2529 times
If the tiles for the shower are square then I would do them as per the floor and not stagger the joints.
- Bikergirl
- Has thanked: 100 times
- Been thanked: 133 times
and if they're a different size to the floor, the grout lines won't match up anyway, even if you go grid, so it really doesn't matter. Maybe lay some out on a floor and see what they look like in grid and staggered. Might be easier to make up your mind once you see them.
- DTWCeramics
- Has thanked: 13 times
- Been thanked: 43 times
Also, be aware that by laying tiles in a brick bond fashion, whether they be staggered or true brick bond, the tiles will show off their bowing more than they would if laid square.
Will still look nice, but you may notice a few corners sticking up further than usual!
P.S, those tiles look like one of ours :P
Cheers!
Matt
Cheers!
Matt
Matt
Thanks for the replies. Excuse my lack of knowledge but what is brick bond fashion and true brick bond? What is the best lay out to ge them even an flat (in laymans terms lol)
