Next step advice?
Blakey
Has thanked: 247 times
Been thanked: 48 times
Next step advice?
Post by Blakey »
I have secured floor boards and laid 15mm exterior ply, screwed at every 6ins and a few extras, there are a couple joins that don't line up exactly along the whole length of the board by approx 1mm.
Do I need to lift the boards and try to get them to line up exactly?
Then what is the next steps before laying the tiles :dunno:
You're never too old to learn something stupid.
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Re: Next step advice?
Post by royaloakcarpentry »
No need to lift and do again.
Next step is to prime with a suitable primer which is recommended by the adhesive manufacturer you are using.
These users thanked the author royaloakcarpentry for the post:
Blakey
Blakey
Post by Blakey »
Thanks once again ROC,
Hopefully last questions on flooring,
All holes were drilled and countersunk before putting in screws, do they need to be filled or treated before tiling, and I am going to fit the units and tile up to the feet, do I need to treat the wood that is not going to be tiled any differently.
transitboy
Has thanked: 379 times
Been thanked: 584 times
Post by transitboy »
No to both question :thumbright:
These users thanked the author transitboy for the post:
Blakey
Return to “Tiling Forum”
