LED lamps/bulbs ?
Energy saving questions in here please
stevewestern
Has thanked: 114 times
Been thanked: 97 times
LED lamps/bulbs ?
Post by stevewestern »
Having had a look through old threads I wondered if there have been any advances in the light quality and reliability of LED GU10 replacements - if so, anyone got any recommendations ?
I am also open to any suggestions for new light fittings to replace the ceiling mounted 3-spots we have all over the place if it makes for better and longer lasting LED light !
philprime
Has thanked: 77 times
Been thanked: 247 times
Re: LED lamps/bulbs ?
Post by philprime »
We replaced 150 gu10s with Philips LEDs at work in January some of the lights are on 15 hours a day not had one fail yet and the light output in very good
stevewestern
Thanks Phil - I guess you may not know what sort they are..?
philprime
Post by philprime »
They are Philips master led spot gu10
stevewestern
Thank you Sir !
I shall start googling right now..
Lana
Has thanked: 36 times
Been thanked: 3 times
Post by Lana »
if not too late for this thread...
I've replaced ALL of my bulbs with LED, mainly due to the energy monitor thingy I've received as a gift from British Gas a year or so ago. The little devil used to raise sharply when the kitchen lights (6 standard halogen spotlights) went on. I started with replacing them with GU10 LED and was amazed at the results displayed. Got literally obsessed with the LED and went around the house replacing all the other bulbs with LED. Not all simpultaneously, mind you, but managed to LED convert the whole house in about 3 or so months - every time I saw a special offer or found special price on line. now the only one left unLED-ed is the ceiling light in sitting room and only because so far I haven't found reasonable replacement for its odd G9 bulbs.
But I would say with each bulb replaced I haven't noticed the difference in the light quality, and have noticed the difference in energy consumption.
way to go!
Has thanked: 736 times
Been thanked: 2341 times
all my bulbs are leds and my total consumption is between 8 and £16 for the whole year :lol:
with all the lights that are normally on its around 28w if i leave the hall bathroom on its another 6-12w
http://www.lightrabbit.co.uk/bulbs-led/ ... tAodNWUAqg
Lana
Post by Lana »
big-all, thanks for the link!
the problem is not as much as in finding the bulbs, but finding the right size :-( the G9 particular seems to be significantly larger in LED versions than in halogen :-( the halogens are 12mm in diametre and the smallest LEd I could find was 20mm. unfortunately, the ceiling light's shades aren't that big, so have to choose wisely. they also have to be dimmable, as there are 6 of them. As far as I can understand, for dimmable LED you have to replce your dimmer with LED compartible one. so, while all is do-able, so far the costs are not convincing. might have to wait for the prices to go down, eventually they will, as the popularity of LEd raises. it has to! ;-)
they have pretty well halved every 18 months or so
heres where i get all my bulbs from now 2 day delivery
http://www.ebay.co.uk/itm/4-7-10W-B22-B ... 2641672%26
stevewestern
Thanks for the further replies - been spending too much on other things as we have only just moved into our new house but will get some soon - the new house already has some cheapo LED's that are not the best advert as light is blue-white (daylight I assume but looks horrible) and some that change colour but put out so little light that it is like being in a nightclub with a powercut !
Can anyone explain why some LED's have lots of LED's and others have 3 or 4 ?
What is the advantage or reason ?
Has thanked: 47 times
Been thanked: 2590 times
stevewestern wrote:Can anyone explain why some LED's have lots of LED's and others have 3 or 4 ?
Cost and brightness.
This one is made from multiple "normal" LED's
This one is made from multiple Surface Mount Technology LED'S
Then you have these. Made from 3-5 single very bright LED's
It depends on light brightness and cost as to which LED's are used to make a lamp. SMT LEDS are now cheap to make but Normal LEDS are even cheaper, but not as bright, although as with most things the price is always coming down.
stevewestern
honda90man
Has thanked: 4 times
Been thanked: 2 times
Post by honda90man »
How do these LED bulbs compare with "normal" energy saving ones from IKEA?
energy saving 22w= 88w 11w=44w
led-------------10w=90w 5w=45w
these are my comparesons 4 x the wattage on a low energy bulb and 9 times the wattage on led bulbs
you will get all sorts off wild claims but until you get someone to verify the actual equivalent you wont go far wrong with my guide
honda90man
"energy saving lamps" are really compact fluorescent tubes. Doesn't matter where they come from. They are totally different so can not be compared as such.
Look at it this way.
CFL comes on slowly and gets brighter.
LED comes on full brightness as soon as you turn on the switch
LED's come in warm white or cool white, CFL's don't
Its a case of each to their own. We have mostly LED's but do have a CFL on the landing, and a couple in the loft.
honda90man
honda90man
I have just got back from shopping at ASDA,where I bought a 6w LED bulb for £3.75.I think they are normally £7.50,but they had them on offer.
Return to “Energy Saving”
