Kitchen Pelmet on corner wall unit
Locked
mike5286
Post by mike5286 »
Hi all,
Fitted my kitchen, all good. Put cornice and pelmets on. along with the plinths, all scribed in. Now then, I have a corner unit on the wall. I need to cut the cornice and plinth for this, and believe its 67.5 degrees. Cant find anything on internet or youtube, that shows me how. Can someone tell me the procedure please. I want to get it right.
Thanks.
Chop
Has thanked: 304 times
Been thanked: 219 times
Re: Kitchen Pelmet on corner wall unit
Post by Chop »
The angle you're looking for is 22.5. there will be two cuts, this angle will probably be preset on your mitre saw.
philprime
Has thanked: 77 times
Been thanked: 247 times
Post by philprime »
If in doubt you can always use this great bit of kit as it will half the angle and you set your mitre saw to suit
Locked
Return to “Kitchen Fitting”
