Decoration is preparation
dynamod
Elephant Man
Has thanked: 592 times
Been thanked: 1444 times
Post by dynamod »
Had this one up on the dec forum to illustrate a post about wet sanding, but thought I'd share it outside the paint slingers room. The door was a pock-marked nightmare on a Victorian house, that badly needed sorting. Originally done in a nondescript brown, the brief was to achieve a smooth finish, high shine, in black.
The door was initially machine sanded, primed and filled with 2-pack to level out the worst of the indentations. Then 2 layers of Toupret Gras a Lacquer surfacing filler, 3 grades of wet sanding, followed by 6 coats of Sikkens Rubbol XD (wet sanded with 1000 and 1200 grit used wet between coats)
A bit out of the ordinary, but very rewarding. The only problem with Rubbol XD is its prolonged drying time, so polythene was stretched over the door with brick tape to prevent damage/flies landing etc.
DURING 1.JPG (92.73 KiB) Viewed 3273 times
DURING 2 (Custom).JPG (104.08 KiB) Viewed 3273 times
DURING 3 (Custom).JPG (162.85 KiB) Viewed 3273 times
Nihil expectore in omnibus
jmcp
Has thanked: 25 times
Been thanked: 14 times
Re: Decoration is preparation
Post by jmcp »
That is an incredible transformation, well done.
Cheers, John
These users thanked the author jmcp for the post:
dynamod
Gadget
Jack Of All Trades
Has thanked: 344 times
Been thanked: 342 times
Post by Gadget »
Great job!.... :thumbright:
These users thanked the author Gadget for the post:
dynamod
By eck! ©
Themissus
Has thanked: 49 times
Been thanked: 4 times
Post by Themissus »
Absolutely stunning! :thumbright:
These users thanked the author Themissus for the post:
dynamod
Return to “Show Case Gallery”
