Just one of them weeks
Grumpy people only in here please
Locked
Cannyfixit
Has thanked: 102 times
Been thanked: 183 times
Post by Cannyfixit »
My fish tank light blew so i replaced it,the following day i rescued some fish from my lads tank because his has sprung a leak,i had 27 fish in my tank and Darren's have eaten all mine bar 3
next day i found my external pump and filter had packed up as well,
I have managed to borrow another pump from a mate until i can raise the cash for a new one
so today i thought sod it get out on the bike and blow the stress away and the batteries flat,
and to top it all it's FLAMIN HOT ::b
come on anything else before i jump off a cliff lol
Wes
Wood Flooring Installer
Has thanked: 379 times
Been thanked: 565 times
Re: Just one of them weeks
Post by Wes »
:lol: You just gotta laugh Canny :lol:
A mate bought nine pirahnas a few years back..One got ill and didn't get chance to blow it's nose before the rest ate it..Ruthless them fish :shock:
Better luck for the coming week mate :thumbright:
Cannyfixit
Well true to my name i cant leave nowt alone,I had a go at trying to find out what had gone wrong with my pump
so took it to bits on top of the pump housing there is a manual plunger to purge the air out of the pump further investigation revealed the plastic rod that holds the diaphragm had snapped
so with the thought was if i cant prime it maybe that's why it isn't working
rooting around the garage i found a piece of stainless rod that was the correct diameter but way to long,cut the rod and tapped new threads on to either end fitted it all back together and the plunger worked like a dream chuffed to bits with my creation i assembled everything back together and connected it back up to the tank
all that effort and the pump still wont suck the water out of the tank
joinerjohn
Has thanked: 17 times
Been thanked: 315 times
Post by joinerjohn »
Missus's lad phoned up yesterday,,, Could I hang a door at their house for them? So called in at work and picked up the tools I thought I'd need. Got there in the sweltering heat only to find the door they wanted hanging was about 3/4 inch less, than the width of the door frame. Had to go out and get some timber to reduce the width of the door opening. Planed the door down, slightly (to fit) and marked the hinges on the door. Took it outside and made the first year apprentice mistake of cutting the hinges to the wrong side of the bloody marks. :wtf: ::b ::b ::b ::b ::b . Re-cut the hinges and managed to get it swinging. What should have normally been less than an hour to do, took over 2, 1/2 hrs with the running about etc. :cb :cb
wine~o
Has thanked: 1415 times
Been thanked: 4024 times
Post by wine~o »
3 goldfish die and a cracked windscreen since friday...
Cannyfixit
wine~o wrote:3 goldfish die and a cracked windscreen since friday...
:lol: :lol: :lol: wine O
well Darren's fish have polished off the last of mine :cb,good news is the new fish have started to greet me when i get home,more likely they are looking for food :roll: either way it's more than what i get from Mrs Canny :lol: :lol:
wine~o
Post by wine~o »
:dunno: sound iscrap...but fat Bob died...so did fan tailed Bob..
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
Your goldfish never heard of seatbelts wine~o ???? :dunno: presumably the airbags failed too :dunno:
wine~o
Post by wine~o »
kellys_eye wrote:Your goldfish never heard of seatbelts wine~o ???? :dunno: presumably the airbags failed too :dunno:
Nope...I could never get the Goldfish to wear a seat-belt...and Big-Bob was driving......stupid Bob took the fuse outta the airbag circuit......... :?
kellys_eye
On a serious note though..... did your goldfish die due to heat? I ask as we've just had an Orf(?) die in our pond.
wine~o
Post by wine~o »
kellys_eye wrote:On a serious note though..... did your goldfish die due to heat? I ask as we've just had an Orf(?) die in our pond.
IF..you want to be serious...then a combination of heat and old age...the three that died were approx 30 years old (And a bit)...30 years is pretty good for a goldfish..or orfe...and would be roughly the equivalent of 70=90 years in human terms...
Has thanked: 47 times
Been thanked: 2590 times
Nice pond
Locked
Return to “The Grumpy corner”
