new patio
trojan62
new patio
Post by trojan62 »
hi all,
this is our new patio that we have just completed.
just outside our back door was a tiny area and then a brick wall which went up a level, the garden goes up to 3 levels.
we decided to do away with the brick wall and all the earth behind it and make ourselfs a patio.
our main problem was to sort out a retaining wall that would hold up the garden.
we didnt want to go to the bother or cost of having a brick one built, so we were goinjg to do it with sleepers, but we were told that the sleepers would have to be around 8 feet high, so that 4 feet could be buried into the earth for the strength of the retaining wall. anyhow, we decided to use Gabions instead which was much less costly and easier to do.
all the work was done by me and the wife, apart from laying the patio slabs. the hardest part was getting rid of the earth, there must have been about 5 ton of it.
in the pictures you can see the results.
cheers,
chris....
IMAG0008 (Small).jpg (107.47 KiB) Viewed 2198 times
IMAG0007 (Small).jpg (101.16 KiB) Viewed 2198 times
IMAG0006 (Small).jpg (106.63 KiB) Viewed 2198 times
6948_470133296397170_703548626_n (Small).jpg (64.91 KiB) Viewed 2198 times
388831_370758823001285_333120318_n (Small).jpg (99.34 KiB) Viewed 2198 times
532093_390489884361512_115248894_n (Small).jpg (84.67 KiB) Viewed 2198 times
311186_390489764361524_557237342_n (Small).jpg (101.08 KiB) Viewed 2198 times
33875_384223434988157_1841577741_n (Small).jpg (75.98 KiB) Viewed 2198 times
16116_390490087694825_1431279026_n (Small).jpg (58.95 KiB) Viewed 2198 times
486875_370774869666347_1564204816_n (Small).jpg (96.84 KiB) Viewed 2198 times
Chop
Has thanked: 304 times
Been thanked: 219 times
Re: new patio
Post by Chop »
That's a great space you have made - good thinking with gabions. What a great year we're having to enjoy it too.! :thumbright:
:thumbleft:
Return to “Show Case Gallery”
