Which CPU
Posted: Mon Jul 15, 2013 10:56 pm
Well guys I tried to fit a pentium 166 into the case the Cloven hooved one so kindly donated but it looked a bit silly sitting in the bottom on it's own and then I found out I couldn't fit a 5 1/4" floppy drive in there so it was a bit of a bust. Thought I'd best do some research.
Sticking with Intel cos I like them it seems the last two generations have both been slated for running hot and generally being a little bit disappointing. The trend seems to be going for more diverse chips with better onboard graphics and power controllers. Jack of all trades springs to mind!
So I was never really comfortable with Haswell and Ivy Bridge seems to be a slightly less good version of the same but I was going to go for a 4770K cos it was the newest!!
Then Rich pointed out that some of the old Sandy Bridge hexacores are being knocked out quite cheaply now. I can get a 3960X for under £500 - they were da bomb a couple of years ago and still pizz all over Haswell now in things like video rendering.
Sooooooo the question is do I go for the modern all singing all dancing but ultimately not enough to swing your pants chipolata
Or go for the older but absolute beast of a chip, bearing in mind that adding a very average graphics card will trounce the Haswells onboard graphics?
Discuss
Discuss
