It's been a long time....
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
I came to this site to find advice and tips on rennovating properties as our place is a 'shed' (seriously, it was made from an old barn as far as we can tell after having removed a few old plasterboard panels and seen the inside!) and in desperate need of many, many DIY projects to make habitable.
One of the projects was to rebuild the fireplace - the original open hearth wasn't the most ideal (as you can see) and we were pleasantly surprised at the extent the fireplace opened out, allowing us to make a decent hearth to house a woodstove which is now our primary heating - the wood coming from the forests outside our place and essentially being 'free' (ok, a £50 licence to gather which gives us enough scope/time to get 3 years worth..... as good as 'free' as you can get ). Since our place is TINY (11m x 5m full extent ) the stove does ALL the heating - at least it does NOW after all the rest of the rebuilding work approaches completion and the insulation is finally fitted.
Anyway, with various hints and tips picked up along the way I thought I'd let other members see what has become of some of the areas I'm attending to. Comments and criticisms are, as always, welcome as I'm the first to acknowledge my amateur status when it comes to all-things DIY.
here's the fireplace project:
- The bricks attached to the front were a bugger to get off....
- original fireplace.jpg (79.75 KiB) Viewed 3591 times
- As we opened the hole it got bigger and bigger!
- digging out.jpg (87.65 KiB) Viewed 3591 times
- The pic shows the leveling compound on top of the concrete I'd added earlier.
- big hole and concrete leveled base.jpg (86.23 KiB) Viewed 3591 times
- Cutting these babies was 'fun' (not!) and I had to improvise at the edges (the small squares) using offcuts as I'm such a skinflint I wouldn't pay for an additional box of tiles to do full sizes narrow bits!
- porcelain tiles fitted.jpg (44.22 KiB) Viewed 3591 times
- The surround was taken from my wifes old bedroom at the in-laws place many years ago. Found in their garage and cut down to size to fit - it was about 3 feet wider than shown in my pics.
- surround fitted.jpg (45.27 KiB) Viewed 3591 times
- Well.... almost. Some rebuilding of the base surround to do but that will get sorted when re-lay the floorboards.
- fireplace finished.jpg (66.18 KiB) Viewed 3591 times
- Wes
- Wood Flooring Installer
- Has thanked: 379 times
- Been thanked: 565 times
Re: It's been a long time....
Nothing to criticise their K_E...Looks very nice mate
- These users thanked the author Wes for the post:
- kellys_eye
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
I quite like the way that looks, it certainly doesn't do it any disfavours in my eyes.I had to improvise at the edges (the small squares) using offcuts as I'm such a skinflint I wouldn't pay for an additional box of tiles to do full sizes narrow bits!
Picture hooks aren't that expensive though are they? (Last photo) Just a nail in the wall would probably do.
- nick200
- Has thanked: 409 times
- Been thanked: 222 times
Look great ke and I may have to nick some ideas there for ours!
Nick
- Cannyfixit
- Has thanked: 102 times
- Been thanked: 183 times
I cant criticise as I don't know what to pick on nice work KE
- kellys_eye
We don't have many too inspiring ideas between us (me and Mrs) so we usually end up doing what we think fits the situation, the budget and/or the availability of 'bits' the mantle came first! The tiles were end-of-range sale items and so on.
The budget ran out before we got around to picture hooks - still saving for them
- Been thanked: 584 times
- Chop
- Has thanked: 304 times
- Been thanked: 219 times
I bet you were glad to get it up and running!
How does the forestry thing work? Is it purely for firewood or can you take any bit of timber you fancy?
- kellys_eye
We live in a forrestry area (on the banks of Loch Awe) and the forrestry allocate areas they've already harvested to anyone interested in collecting the 'off cuts' - these range from branches to log off cuts some 1 to 4 metres in length it varies enormously between sites.
The £50 fee (for paperwork really) gives you 3 months to collect as much as you can from your allocated area - our last allocated area got us something like this (picture was taken only half way through our colletion period, the finished pile is MUCH bigger!). The site are usually left for a year or two before they are available so the wood is well seasoned when you collect it.
We reckon we've got 3 years worth based on last years consumption (and we've increased the house insulation considerably since then too). Living in the back end of beyond does have its advantages!
- Pile 1.jpg (118.69 KiB) Viewed 3439 times
- Chop
