Downstairs Cloakroom - More plumbing
mcluma
Has thanked: 5 times
Been thanked: 26 times
Post by mcluma »
Seeing how much we all like plumbing, I thought I show you my journey in getting the downstairs cloakroom ready for tiling
Although the tiling has to wait until I have the stairs done, so I will just get all the plumbing done, and we can use it in the meantime, as it’s our only cloakroom on the ground floor
I recently ripped everything out, to make it ready for the new suite, I leave the current tiling as it’s the correct height and it’s solid on a concrete floor, so it will be a perfect base to tile over
My wife has choosing this fancy egg style WC with a pod as basin. As you can see its round – and it has to fit into a corner – on top of it all – access to all the plumbing is bad. – later I will make an oak planchette to fit in the corner
I have fitted the tap and waste trap, and to make life a bit easier I use these flexible tap connecters
I have placed in the corner 2 wall plates which will take the shut-off valves
Here the shut-off valves – this type have a self sealing ring, so actually no PTFE tape is needed, but I still do it, as well as a bit of flexible PTFE – just to make sure it doesn’t leak
And fitted
Next up is the wc.
Unfortunately it doesn’t fit, at the back of the pan there is a bar, which sits directly over the waste pipe, so that has to come out – nothing is simple in life
Here the hole in the ground
Modifying the WC
The piece that has to come out
Part one done
Ready for part two
Next up – water to the WC, and pipes for the central heating
Flicker links removed, Pics attached. Mod 2.
Timllfixit
Has thanked: 146 times
Been thanked: 209 times
Re: Downstairs Cloakroom - More plumbing
Post by Timllfixit »
I like the job on the loo. What did you cut it with? A diamond blade on the angle grinder?
mcluma
Post by mcluma »
Timllfixit wrote:I like the job on the loo. What did you cut it with? A diamond blade on the angle grinder?
indeed a diamond blade on a small angle grinder
Return to “Show Case Gallery”
