Tile over hole in the wall?
Mickarious
Post by Mickarious »
I have had an old heating clock removed from my kitchen which was located in the middle of a tiled wall. I have some spare tiles I can fit but I have a gaping hole in the wall as per the attached picture. Will I need to put some plasterboard over this?
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Re: Tile over hole in the wall?
Post by royaloakcarpentry »
Yes and no.
Depends on the tile size compared to the hole size and also where the tile joint falls in relation to it.
Mickarious
4 tiles fills the entire space. The bottom right tile will have to be cut in a reverse 'l' shape to fit around the switch plate. 2 tiles to the left abut the hole by about half an inch
royaloakcarpentry
Sounds like it should be ok. Just be careful when tightening the screws on the face plate.
Return to “Tiling Forum”
