Distance of hob from tower unit
Locked
CHIPPYAL
Has thanked: 51 times
Post by CHIPPYAL »
customer of mine has designed his own kitchen layout which has a hob in close proximity to a oven housing (tower) can you confirm the minimum distance the hob should be away?
many thanks
Al
wine~o
Has thanked: 1415 times
Been thanked: 4024 times
Re: Distance of hob from tower unit
Post by wine~o »
From my own Hob install instructions
"Adjacent side walls above the hob must not be nearer than 100mm and should be of heat resistant material."
Your customers hob may well have different instructions.
Personally, I'd allow at least 300mm either side of the hob as working space.
Has thanked: 736 times
Been thanked: 2341 times
is it gas or electric :dunno:
CHIPPYAL
Post by CHIPPYAL »
Gas, sorry i should have said
unfortunately hob is second hand so no instructions
yes a foot /300mm comes to mind definately more than 6"/150mm but these are just figure that pop into my head source unkown :dunno: :dunno:
philprime
Has thanked: 77 times
Been thanked: 247 times
Post by philprime »
Minium distance should be 300mm but worth checking the manufacturer website and finding instructions as some do state a set distance
joinerjohn
Has thanked: 17 times
Been thanked: 315 times
Post by joinerjohn »
I have seen MI's quote a minimum distance of 150 mm from an adjacent cabinet, but surely common sense would dictate a distance of 300 mm to allow for pan handles. :wink:
Locked
Return to “Kitchen Fitting”
